NESSHINDO's avatar
NESSHINDO
To many satellites?
I have 1 RBR50 and two satellites. One satellite in kitchen and the other on the first floor. My router is in the fuse box. Latest firmware. Sometimes i have internet drop outs.  Support desk told...
  • FURRYe38's avatar
    Yes.
    So best way to check this is to test just the RBR alone to see how well it does with out any RBS online. Then try just 1 RBS, placed out at 30 feet, maybe on 2nd floor up from where the RBR is on 1st level. Test the system out to see how it works. IF you don't need the 2nd RBS, I'd keep it for backup in case something happens.
