Bailly's avatar
Bailly
Follower
Mar 30, 2018
top light ring
Is there a way to turn on the top light so that it shows it is operating normally?
1 Reply
  • FURRYe38's avatar
    I believe NG only shows working and successful operation with the BLUE led for a short time then under normal operation, it's OFF. If there is a problem then the LED would elluminate. I presume this is how NG designed it.
