OrbiDissapoint
Mar 03, 2018Tutor
Totally disappointed - avoid Orbi
I have spend hours trying to fix something that should be so basic. I don’t want any complex features, just simple basic reliable internet connection. My old, very old Apple AirPort Extreme seemed ...
Maca1010
Mar 05, 2018Aspirant
We also had same drop issue for long time. The only tempolary fix I found was to Block and Allow the device under Access Control and turing off/on the wifi on device. We use the rounter in our office and 20 devices are connected all the time and somehow one device always drops connection. I wish Netgear could annouce something that they are fixing this its annoying.
- FURRYe38Mar 05, 2018Guru - Experienced User
community.netgear.com/t5/Orbi/OrbiOS-MR-2-1-issues
Maca1010wrote:We also had same drop issue for long time. The only tempolary fix I found was to Block and Allow the device under Access Control and turing off/on the wifi on device. We use the rounter in our office and 20 devices are connected all the time and somehow one device always drops connection. I wish Netgear could annouce something that they are fixing this its annoying.
