RodrigoCF
Aug 29, 2019Follower
touch controls not working
Just bought the orbi voice and the touch controls does not ilumminate and does not work i can only raise the volume with alexa. cant control anything.
Bdoty47
Aug 28, 2020Aspirant
I am having the same issue with my Orbi voice. Top controls stop working and volume cannot be controlled by voice either. Am on latest firmware and router, satellites and internet service are all working fine.
- 1Ghost1Aug 28, 2020AspirantI spent a lot of hours with netgear support at 3 levels but none of them could help and were not able to fix the issue. I think the wit time to speak to support all 3 was over an hour and then another couple of hours to troubleshoot the problem unsuccessfully. We even downgraded to A couple of previous firmware versions without any luck. I ended up returning and getting another brand mesh router.
My bet is some of these units have some conflict or fault with latest Firmware which makes the top buttons inoperable.- bjborbiAug 28, 2020Aspirant
After much back and forth and continued troubleshooting with level 3 support I had to send in my unit for a replacement unit -- having to pay the shipping myself mind you. Hopefully the new unit will work but considering this ongoing thread of issues I am not optimistic. The initial unit did have a functioning volume bar on first power up but ever since it never worked. Even on factory reset, which makes me think these are alot of faulty hardwares.
- yesdaloAug 29, 2020Guide
I just fixed the problem thanks to Mstrbig help:
Find out what IP address your Orbi Voice is on and login diretly to the Voice, with that ipaddress: ie 192.168.1.x/debug.htm
Then Upgrade Touch Board Firmware. That should work.
