Jeremyinsf
Dec 04, 2018Apprentice
TP-Link HS-105 wifi power plugs won't stay connected
One of my many, many problems with the 2.2.1.210 firmware is that my TP-Link HS-105 plugs drop off all the time and can't stay connected. They come and go, come and go. I have about a half dozen of...
ekhalil
Dec 05, 2018Master
Jeremyinsf wrote:
.......... that my TP-Link HS-105 plugs drop off all the time and can't stay connected. They come and go, come and go. I have about a half dozen of them and they all do it - sometimes together, sometimes at different times. ............
- Have you tried to set wireless security to AES in the devices (don't use auto)?
- Also some devices can't handle long wifi passwords or special characters in the passwords.
- JeremyinsfDec 05, 2018Apprentice
@ ekhalil - Specifci to the HS-105 plugs and AES, I don't see a way to do that. Someone else previously posted (on a different post) about that, but, Kasa app does not seem to have a setting either after setup or during.
You get to pick a wifi network on setup, and an icon/name to display once it's configured, but nothing else. I've checked the documentation, and I also reset a plug this evening to go through it all again, and confirmed this.
Am I missing something?
- ekhalilDec 06, 2018Master
Do you get prompted for Wifi password? Have you tried to change the wifi password to a simpler password or -preferably- to test with no password?
- JeremyinsfDec 06, 2018Apprentice
Do you have these plugs and have you tried this yourself? You didn't answer the last question about AES, you pivoted to a new concept.
