Jeremyinsf
Dec 04, 2018Apprentice
TP-Link HS-105 wifi power plugs won't stay connected
One of my many, many problems with the 2.2.1.210 firmware is that my TP-Link HS-105 plugs drop off all the time and can't stay connected. They come and go, come and go. I have about a half dozen of...
JoeCymru
Dec 06, 2018Virtuoso
Are you using fixed IP addresses? If not, try giving the HS105's static IP addresses during a period of good connection.
- JeremyinsfDec 06, 2018Apprentice
JoeCymru , that is not supported on this product.
