Chuck_M
Mar 27, 2019Mentor
Traffic Meter Inop?
After reading a post on here about the traffic meter being broke, I checked mine out.
With RBK50 (3 RBR50's) all at FW 2.3.1.44 it seems the connection time remains at zero under Advanced | Tr...
Mar 31, 2019Guru - Experienced User
Lets try to keep all this to one post if possible:
It seems to be a know issue.
Thank you Blanca_O for looking into this.
Chuck_M
Apr 01, 2019Mentor
FURRYe38 -- the other posting I read was centering around DST being checked. Mine has nothing to do with that and is inop under all conditions. Fortunately the NG support team has reached to me and I will post whatever the found solution is here...
- FURRYe38Apr 01, 2019Guru - Experienced User
:smileywink:
