murchman
Nov 30, 2016Apprentice
Traffic statistics not working
Installed the Orbi router and satellite last night and everything is working really well except the Traffic statistics. I tried it with and without the traffic meter on and it remains at zero, I also...
murchman
Dec 01, 2016Apprentice
Update, I need a full reset and now it's working. Must have been an issue with the firmware update.
Vandergraff
Dec 24, 2016Apprentice
I have the same issue.
I am on the latest firmware and have re-booted the router.
Date and time is correct in logs
But if I enable 'traffic meter' that page says 'Current Date/Time: Wednesday,31 Dec 1969 04:04 PM'
If I disable trafic meter that page is now correct 'Current Date/Time: Saturday,24 Dec 2016 11:51 PM'
Ideas?
- VandergraffDec 28, 2016Apprentice
Any ideas?
- RonV42Dec 29, 2016Luminary
May be a bug in the firmware. But you may want to check the time zone first in the advanced settings (see attached image). If it is correct then I would suggest you open a support ticket.
- DarrenMDec 29, 2016Sr. NETGEAR Moderator
Have you tried a factory reset like murchman he said that corrected the issue for him.
DarrenM
