murchman
Nov 30, 2016Apprentice
Traffic statistics not working
Installed the Orbi router and satellite last night and everything is working really well except the Traffic statistics. I tried it with and without the traffic meter on and it remains at zero, I also...
Vandergraff
Dec 30, 2016Apprentice
Thanks - at this point I am thinking of putting the Orbi into AP mode.
WiFi coverage is stunning - but the router and app features / options are lousy....
Will go back to using an Asus RT-AC68 running asuswrt merlin as my router and the Orbi for WiFi.
Hoping Netgear will add to features and options in the future
Vandergraff
Dec 31, 2016Apprentice
One more go at this.
Did a factory reset and now can see traffic stats.
If I enable traffic meter it looks like the max monthly limit is 100,000 MB (100GB).
Comcast now has a monthly cap of 1 TB (1000 GB) - which I hate as a concept (as we all use more data 1 TB will become much more normal and comcast can monetize - we pay for a speed not a cap).
However it seems the Orbi can't check traffic above 100 GB?
- murchmanDec 31, 2016Apprentice
I have comcast as well and have gone over this month but wasn't using the router to limit the bandwidth. When I just tried to set it I see the problem you pointed out. I would start a new thread on that issue so hopefully Netgear sees it.
- swrtwdrvDec 31, 2016Apprentice
Max can be set to 999,999 Mb
- VandergraffDec 31, 2016Apprentice
Good point - would still be good to have another digit as (hopefully) caps increase
