Dbalur
Dec 25, 2023Follower
Transferring registration to new email address
How do I transfer my Orbi registration to new email address
schumaku
Dec 26, 2023Guru - Experienced User
michaelkenward wrote:If you have access to MyNetgear from the old email address you can "Unregister" it there and add it to the new address.
Doubt Netgear does allow re-registration of previously registered devices, neither on a new or on the same old account.
michaelkenward
If Netgear didn't allow that there would be no need for an "Unregister" button like this.
It does, I have used it.
But it depends on what you mean by "Register". (See the FAQ.)
You cannot transfer registration for warranty and support, but you can transfer it for things like Anywhere Access or anything that ties your device and its serial number to the Netgear cloud. That's probably more important to most people, and it a regular issue around here.
- FURRYe38Dec 26, 2023Guru - Experienced User
Same here, used it as well just last week as I accidently let a RBR960 get registered. I was able to get it de-registered from my account.
