bcssspray
Sep 30, 2020Follower
Transmit power adjustment
Is the antenna power adjustable on either the Orbi RBK852 or the Nighthawk RAX series? Thank you.
CrimpOn
Sep 30, 2020Guru - Experienced User
bcssspray wrote:Is the antenna power adjustable on either the Orbi RBK852 or the Nighthawk RAX series? Thank you.
Like the RBR50, he User Manual for the RBK852 does not mention "Transmit Power". On the RBR50 this setting is on the "Advanced Wireless" menu that is not described in the User Manual. There is a community forum specifically for the AX product line. If the question is posted in that forum, someone who has this model could probably answer quickly.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
There is a similar community for for the NIghthawk AX series:
Good Luck
