marty_bent
Oct 08, 2018Follower
TreeHue Christmas lights
I just purchased TreeHue christmas tree lights and they will not connect to my network. I tried them at a friends that uses Google Mesh and it connected. This is how I know the device works. It will ...
Oct 09, 2018Guru - Experienced User
What FW is currently loaded?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Try channel 10 as well. Try setting WPA security to WPA, then try WPA2 and AES only. As a quick test, disable WPA security on the Orbi and see if it will connect, then re-enable WPA security.
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. So try this out as well.
Blanca_O
Oct 14, 2018NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information FURRYe38 provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team
