Ru058197
Aug 25, 2016Aspirant
Tri-band Question
Quick question. The specs say tri-band, however from what I am reading, one of these bands is dedicated to the router>satelite communication (from what I understand, that is to achieve perfromance w...
VE6CGX
Aug 26, 2016Master
Tri-band? It is dual band with 3 radios. one radio for 2.4GHz band, two radios for 5GHz band split in two, lower half and higher half.
- Ru058197Aug 26, 2016Aspirant
VE6CGX wrote:Tri-band? It is dual band with 3 radios. one radio for 2.4GHz band, two radios for 5GHz band split in two, lower half and higher half.
Confused,Even the website says "Tri-band" for the Orbi Wireless AC 3000
https://www.netgear.com/home/products/networking/orbi/?cid=wmt_netgear_organic
Best Buy has it listed as Tri-band as well
