wilro15
Jan 03, 2023Tutor
Trouble accessing local network devices from Orbi satellite connection
My problem: Unable to "see" a Mac Mini server on my local network when the client device is connected via Wifi to a satellite. If connected to the main router via Wifi or cable, it is fine. In a day...
- Jan 03, 2023
Try it with nothing connected to the adtran router other than the orbi router.
If you're using a wired backhaul go
adtran---->orbi wan port----->switch/devices/satellites.
Because in ap mode, the adtran is managing the routing/dhcp/nat.
Jan 03, 2023Guru - Experienced User
- wilro15Jan 03, 2023Tutor
It is using a wireless backhaul. Why would I need to unplug the other network cables from the Adtran?
- wilro15Jan 04, 2023Tutor
It is now working!
The fix, as you suggested, was to run a Cat6 cable from the Mac Mini into one of the Orbi's ports directly, eventhough it is "only" in AP mode and the Adtran router is doing DHCP, etc.
The Orbi is, for some reason, blocking traffic from going "through" it from Wifi to something connected to it's ports indirectly, such as via Adtran router, to another device.
It so odd that this just started to happen, as my setup has been this way for over 6 months and was fine.
Thanks so much for helping.
- FURRYe38Jan 04, 2023Guru - Experienced User
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-System - Mikey94025Jan 04, 2023Hero
wilro15 wrote:It is now working!
This seems more like a workaround, not a fix. Your system is still operating incorrectly if wireless clients of the RBS cannot access other home network devices (they should have access, even in AP mode - Right?). Hopefully some future firmware release will fix this regression.
- plemansJan 04, 2023Guru - Experienced User
Mikey94025 you're correct. It is a workaround. But I'm not Netgear. I don't do the coding/firmware changes.
So the user can try downgrading or use the method that worked for the time being. My goal is to get some ones setup back up and functioning to the best we can and hope netgear engineers see issues like this on here to try to figure out what changed or why it changed.
