wilro15
Jan 03, 2023Tutor
Trouble accessing local network devices from Orbi satellite connection
My problem: Unable to "see" a Mac Mini server on my local network when the client device is connected via Wifi to a satellite. If connected to the main router via Wifi or cable, it is fine. In a day...
- Jan 03, 2023
Try it with nothing connected to the adtran router other than the orbi router.
If you're using a wired backhaul go
adtran---->orbi wan port----->switch/devices/satellites.
Because in ap mode, the adtran is managing the routing/dhcp/nat.
Mikey94025
Jan 03, 2023Hero
wilro15 wrote:
- Any device connected via cable, such as another computer in my office works fine.
Interesting, so devices connected by wi-fi cannot talk to your Mac Mini but if connected by ethernet they can?
Are your satellites wired or wireless to the Orbi base?
When you ping, is it by DNS name or by IP address of the Mac Mini? If it is by DNS, also test if pinging by IP address works when wireless connected to the satellite.
