wilro15
Jan 03, 2023Tutor
Trouble accessing local network devices from Orbi satellite connection
My problem: Unable to "see" a Mac Mini server on my local network when the client device is connected via Wifi to a satellite. If connected to the main router via Wifi or cable, it is fine. In a day...
- Jan 03, 2023
Try it with nothing connected to the adtran router other than the orbi router.
If you're using a wired backhaul go
adtran---->orbi wan port----->switch/devices/satellites.
Because in ap mode, the adtran is managing the routing/dhcp/nat.
Jan 03, 2023Guru - Experienced User
wilro15
Jan 03, 2023Tutor
It is using a wireless backhaul. Why would I need to unplug the other network cables from the Adtran?
