Sisy530
Jan 12, 2022Aspirant
Trouble connecting HoneywellHome Thermostat T9 to Netgear Nighthawk
Hi, I am having trouble connecting a Honeywell Home Thermostat to my wifi network Thermostat: Honeywell Home T9 Router: Nighthawk CAX30 AX2700 Detail Wifi set up as 2.4G and 5G with WPA...
Jan 12, 2022Guru - Experienced User
Try this.
Disable the router.
Hotspot your phone with the same ssid/password as you router.
Get the thermostat connected and updated.
then shut off the hotspot and turn the thermostat back on.
I had an instance when my t6 first came out that it needed to connect and update and it wouldn't on an AX device.
so I'd try that.
- Sisy530Jan 13, 2022Aspirant
Thanks for the tip. Unfortunately, the Thermostat doesn't find my iphone hotspot either. Maybe it's an iphone problem. I'll try setting up an older wifi router and see if that lets me connect and update the firmware.
- plemansJan 13, 2022Guru - Experienced User
If the thermostat isn't finding the phone or the router, it points at it being a thermostat problem.
