Sisy530
Jan 12, 2022Aspirant
Trouble connecting HoneywellHome Thermostat T9 to Netgear Nighthawk
Hi, I am having trouble connecting a Honeywell Home Thermostat to my wifi network Thermostat: Honeywell Home T9 Router: Nighthawk CAX30 AX2700 Detail Wifi set up as 2.4G and 5G with WPA...
Sisy530
Jan 13, 2022Aspirant
Thanks for the tip. Unfortunately, the Thermostat doesn't find my iphone hotspot either. Maybe it's an iphone problem. I'll try setting up an older wifi router and see if that lets me connect and update the firmware.
Jan 13, 2022Guru - Experienced User
If the thermostat isn't finding the phone or the router, it points at it being a thermostat problem.
