dblakey
May 03, 2019Aspirant
trouble connecting new wireless printer
New wireless printer - HP 9025. Wouldn't connect to my old wifi network because of range extender on my old network (according to HP tech rep.). So I just installed Orbi RBR50 to get a better quali...
- May 03, 2019Thanks. I found the webpage , changed the channel on 2.4gHz to 8 and that did the trick. Printer works now.
May 03, 2019Guru - Experienced User
Change channels on the routers web page under Basic tab/Wireless settings.
If the printer didn't connect to the orbi while security was dissabled, possible the printers wifi is faulty.
dblakey
- FURRYe38May 03, 2019Guru - Experienced User
Sounds like the printers wifi adapter is particular on channels. Glad you found it. Please mark your post as solved so others will know.
Enjoy. :smileywink:
- michaelkenwardMay 04, 2019Guru - Experienced User
Glad to see you got it sorted. For future reference, the usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi and configure the printer's settings.
There's a chance that the utility has a way to tweak channels.
