dblakey
May 03, 2019Aspirant
trouble connecting new wireless printer
New wireless printer - HP 9025. Wouldn't connect to my old wifi network because of range extender on my old network (according to HP tech rep.). So I just installed Orbi RBR50 to get a better quali...
- May 03, 2019Thanks. I found the webpage , changed the channel on 2.4gHz to 8 and that did the trick. Printer works now.
dblakey
May 03, 2019Guru - Experienced User
Sounds like the printers wifi adapter is particular on channels. Glad you found it. Please mark your post as solved so others will know.
Enjoy. :smileywink:
