JohnEP
Jul 08, 2018Aspirant
Trouble connecting wireless printer
Just bought and install the Orbi Home Mesh WiFi System (RBK33) and everything connected fine except my HP CP1525nw printer ... I have tried everthing I knew and anything I could find on the ...
Jul 08, 2018Guru - Experienced User
What wireless security modes are you using? Try WPA and TPIK then try WPA2 and AES and see if the printer will connect.
JohnEP
Jul 11, 2018Aspirant
Thanks for your reply ... I change the secrity .... still didn't connect .... Any other ideas? ... Thanks for all help
- UlairiJul 11, 2018Luminary
Try changing the 2.4GHz channel on the Orbi router to a fixed value that is Channel 11 or lower. The Orbi has all 13 channels but many devices and especially printers only connect on channels 1 - 11. Because Orbi automatically selects the clearest channel, it often defaults to 13 to avoid neighbourhood congestion. But older devices can't see that channel.
Please post back with results.
- JohnEPAug 08, 2018Aspirant
Thanks for your suggestion ... Been out of town and am back ... just tried changing the channel and no help .... maybe this printer is just to old?
- FURRYe38Jul 12, 2018Guru - Experienced User
How close is the printer to the router or satellite?
To see if the printer will connect at all to the Orbi at all wirelessly, set the wireless security mode to Disabled or Open on the Orbi router Temporarily. Then try to connect the printer to the Orbi. Will it connect then?
Re-enable WPA2 after testing the printer.
