JohnEP
Jul 08, 2018Aspirant
Trouble connecting wireless printer
Just bought and install the Orbi Home Mesh WiFi System (RBK33) and everything connected fine except my HP CP1525nw printer ... I have tried everthing I knew and anything I could find on the ...
Mikey94025
Jul 11, 2018Hero
Did you reset and reconfigure your wireless printer using the Orbi's SSID? Is the problem with the printer connecting to the wireless network or your PC clients nor being able to see the printer? If the latter, also uninstall/reinstall the printer driver.
Some people have issues with their wireless printers after they replace an older wireless router with the Orbi. It's not sufficient to just name your SSID the same and hope that all your clients will still work. Some of them, like printers, are particular and need to be reconfigured even using the same wireless settings as before.
