JohnEP
Jul 08, 2018Aspirant
Trouble connecting wireless printer
Just bought and install the Orbi Home Mesh WiFi System (RBK33) and everything connected fine except my HP CP1525nw printer ... I have tried everthing I knew and anything I could find on the ...
JohnEP
Jul 11, 2018Aspirant
Thanks for your reply ... I change the secrity .... still didn't connect .... Any other ideas? ... Thanks for all help
Jul 12, 2018Guru - Experienced User
How close is the printer to the router or satellite?
To see if the printer will connect at all to the Orbi at all wirelessly, set the wireless security mode to Disabled or Open on the Orbi router Temporarily. Then try to connect the printer to the Orbi. Will it connect then?
Re-enable WPA2 after testing the printer.
