LoboTommy
Jan 04, 2019Luminary
Trouble in stability Orbi rbk40
So, I have some issues. My setup are one rbr20 and three rbs20. They are wireless backhauled. Internet is provided by altobox Norway, fibre optic network. Modem is bridged, leaving the rbr20 as th...
- Mar 01, 2019Finnaly, the solution!
After talking alot with support, they guided me to the newest manually update of the firmware
https://kb.netgear.com/000060607/RBR20-RBS20-Firmware-Version-2-3-0-28
Updated, and finally stability!
ekhalil
Jan 04, 2019Master
- What is the approximate distance between the Router and Satellites?
- What type of wired devices do you have connected to Orbi? Any speakers (e.g. Sonos)?
- Please toggle the Daisy Chain setting that you find in the GUI under >> ADVANCED >> Advanced Setp >> Wireless Setup
LoboTommy
Jan 09, 2019Luminary
Distance beteeen rouyer and satelites varies. About 10-15 meters (i live in a metric country). Lot of strange walls to signal through though.
Two wired units connected. A PS4 pro wired directly to the router, and a stationary computer wired to one satellite. Rest of the house is wireless.
Daisy Chain has been toggled on and off numerous times, without any difference.
