LoboTommy
Jan 04, 2019Luminary
Trouble in stability Orbi rbk40
So, I have some issues. My setup are one rbr20 and three rbs20. They are wireless backhauled. Internet is provided by altobox Norway, fibre optic network. Modem is bridged, leaving the rbr20 as th...
- Mar 01, 2019Finnaly, the solution!
After talking alot with support, they guided me to the newest manually update of the firmware
https://kb.netgear.com/000060607/RBR20-RBS20-Firmware-Version-2-3-0-28
Updated, and finally stability!
Jan 09, 2019Guru - Experienced User
Also after you set up the router, do a Backup of the routers configuration to file. Keep this file for safe keeping later on should you need to do a reset again. Saves time.
Good Luck. :smileywink:
LoboTommy wrote:
I'm so bad with square feet. But I used an online converter.... 100 Square Meters =
1,076.3910 Square Feet.
There is at least 15 meters inbetween.
Channel 11 in 2.4ghz is set, cuz it was unused by any neighbours (used Wi-Fi analyzer)
The 5ghz is also set to a free channel, though I can't recall witch atm.
All these settings are toggled on an off in various combinations with little to no effect.
In the end, I factory reset the router and satelites, and set it up from scratch. Now it's stable again
LoboTommy
Mar 01, 2019Luminary
- FURRYe38Mar 01, 2019Guru - Experienced User
Thanks for coming back and letting us know. Glad the new FW works better.
Enjoy.
