Jimhoek's avatar
Jimhoek
Trouble keeping my GW security cameras connected to Orbi
I could really use some help… I have spent the last three weeks on the phone with GW security and Orbi technical support. I have 16 camera home security system, through GW, the cameras are run through...
  • CrimpOn's avatar
    CrimpOn
    Feb 09, 2024
    It might be worth asking GW how their NVR discovers cameras on the network.
    Some systems send out a broadcast on a particular network port, "Any cameras out there?" and listen to see which devices respond.  Other systems may create an internal table of IP addresses, and if the cameras change IP addresses they get "lost".
    Any time the router gets rebooted, or any time the entire network restarts because of a power outage, every device may need to refresh the network connection.  Unless the router has reserved a specific IP address for devices such events could cause devices to change IP addresses.  There are posts on the forum quite frequently about printers disappearing which happens when computers have learned, "the printer is at IP xxx.xxx.xxx.xxx" and one day it is no longer there.
    Good Luck with GW.
