Jimhoek
Feb 08, 2024Aspirant
Trouble keeping my GW security cameras connected to Orbi
I could really use some help… I have spent the last three weeks on the phone with GW security and Orbi technical support. I have 16 camera home security system, through GW, the cameras are run through...
- Feb 09, 2024
It might be worth asking GW how their NVR discovers cameras on the network.
Some systems send out a broadcast on a particular network port, "Any cameras out there?" and listen to see which devices respond. Other systems may create an internal table of IP addresses, and if the cameras change IP addresses they get "lost".
Any time the router gets rebooted, or any time the entire network restarts because of a power outage, every device may need to refresh the network connection. Unless the router has reserved a specific IP address for devices such events could cause devices to change IP addresses. There are posts on the forum quite frequently about printers disappearing which happens when computers have learned, "the printer is at IP xxx.xxx.xxx.xxx" and one day it is no longer there.
Good Luck with GW.
Jimhoek
Feb 09, 2024Aspirant
Thank you… After doing some research last night it appears that my problem is on the NVR not Orbi. All of my cameras are set up individually when checking the Orbi system. All of them are set individually, and all set as “wired. LAN” I guess it’s time to go back to GW and figure out what’s going on on their end. Thanks again!
CrimpOn
Feb 09, 2024Guru - Experienced User
Good Luck with GW.
- JimhoekFeb 09, 2024AspirantYou’re the best… That’s exactly what was happening. I had gone into Orbi and set up all of my cameras as.LAN wired connections, but I forgot to do that with the NVR. I just went in and set that one in Orbi so keeping my fingers crossed that I retain connections on everything. Thanks again again for all of your help.
