DBethune
Apr 28, 2020Initiate
Trouble setting up Alexa on Orbi Voice
I was recently given and Orbi router with Orbi Voice Satellite and got everything set up fine until it came to Alexa. I am getting an Amazon login timeout when trying to set up Alexa. I spent almost ...
- Apr 30, 2020This works now, thanks so much
Buc11t
Apr 29, 2020Initiate
Having the same issue. New out of the box today and most things took 2-3 goes to setup for some reason but turning on Alexa is a fail. I log in to Amazon and while I’m being redirected back into app, it times out.
Firmware updated as soon as it connected.
- KurzweilfreakApr 30, 2020AspirantSame here - new kit from Amazon. Tried setting up and everything works fine with the exception of adding Alexa.
- KurzweilfreakApr 30, 2020AspirantI just figured out what the issue was - I was trying setting this up on my iPhone. Once I tried from a Samsung A50 Android mobile the setup worked immediately. I did notice that on iOS the setup app opened the Amazon app and not the webpage to try authentication. On the Android Mobile the Orbi app opened the Amazon website and then completed the setup fine.
I hope this helps anyone else experiencing this issue.
