DBethune
Apr 28, 2020Initiate
Trouble setting up Alexa on Orbi Voice
I was recently given and Orbi router with Orbi Voice Satellite and got everything set up fine until it came to Alexa. I am getting an Amazon login timeout when trying to set up Alexa. I spent almost ...
- Apr 30, 2020This works now, thanks so much
DBethune
Apr 30, 2020Initiate
That did the trick! Thanks so much!
Buc11t
Fixed it for me too. Thank you
For the remote management issue I had to go through the router config to enable it - the app couldn’t do it.
Hope NETGEAR are reading this and fixing them cause I’m pretty tech savvy but this was pi$$ing me off spending so much time setting it up.
