DBethune
Apr 28, 2020Initiate
Trouble setting up Alexa on Orbi Voice
I was recently given and Orbi router with Orbi Voice Satellite and got everything set up fine until it came to Alexa. I am getting an Amazon login timeout when trying to set up Alexa. I spent almost ...
- Apr 30, 2020This works now, thanks so much
schacko210
Apr 30, 2020Initiate
If this helps anyone with an iPhone, my setup worked when I deleted my Amazon app from my iPhone. It forced Orbi to route the login to the browser and that immediately connected. Seems to be an issue with the Amazon app, not the Orbi. It was easy enough to add the Amazon app back once I got the Alexa working on the Orbi.
Yukiiiii
May 01, 2020Initiate
Thank you very much!
I had a day.
Removing the Amazon app worked fine.
