Gridironcoach
Jun 03, 2018Aspirant
Trouble with Orbi app
Is there any way to get access to my password to be able to control my app. I’m answering my questions, but it keeps saying invalid answers. They are the right answers for sure. It’s very frustrating ...
- Jun 18, 2018
If you can not remember that password you may need to factory reset the unit by holding the reset button for 10+ seconds this will set it back to password but you will have to go through the orbi setup again.
DarrenM
DarrenM
Jun 04, 2018Sr. NETGEAR Moderator
You may need to try and reset the password try using the web.
https://www.netgear.com/mynetgear/registration/login.aspx
DarrenM
- GridironcoachJun 16, 2018Aspirant
How do I reset the password from there?
I’m having trouble with the admin password actually. I’m able to log in to my account with my email.
- DarrenMJun 18, 2018Sr. NETGEAR Moderator
are you talking about the password to log into your router to access the settings?
DarrenM
- GridironcoachJun 18, 2018AspirantThe admin password. Yes, I can’t control the settings at all.
