Gridironcoach
Jun 03, 2018Aspirant
Trouble with Orbi app
Is there any way to get access to my password to be able to control my app. I’m answering my questions, but it keeps saying invalid answers. They are the right answers for sure. It’s very frustrating ...
- Jun 18, 2018
If you can not remember that password you may need to factory reset the unit by holding the reset button for 10+ seconds this will set it back to password but you will have to go through the orbi setup again.
DarrenM
DarrenM
Jun 04, 2018Sr. NETGEAR Moderator
You may need to try and reset the password try using the web.
https://www.netgear.com/mynetgear/registration/login.aspx
DarrenM
Gridironcoach
Jun 16, 2018Aspirant
How do I reset the password from there?
