engin33r_atl
Dec 03, 2016Guide
Trouble with WiFi quality
I just moved into a new house and promptly installed an Orbi. The router is installed in the basement, and the satellite is installed upstairs. The house is 2 floors with a basement. It's not a huge ...
peteytesting
Dec 03, 2016Hero
it sounds like you maybe connecting to the router in the breakfast area instead of the sat and this maybe why its lower , you may need to play with pklacement or adjust the power level on the router
- engin33r_atlDec 03, 2016Guide
How do you feel about the general placement of the router and the satellite? Are they in OK locations? Not too close or too far apart? I could move the router into the basement bonus room (against the wall shared with the basement bedroom), which would be a more central location. I could also move the satellite to just about anywhere, including the 2nd floor.
- peteytestingDec 03, 2016Hero
prob a good idea as long as the 5 gig backhaul will take the distance without too much loss
it really does sound like maybe a single big hunking router like an r8500 would have covered the lot if it where placed on the first floor and the orbi system might just be a case of too much wifi for what is by the sounds of it quite a small space to fill , eg it could be a case of too much of a good thing
I just ran a little test where I unplugged the satellite and ran a speed test from the breakfast area where I was getting spotty coverage. With the satellite powered off, I got 6.6 megabits down and 12 up. So, to me this tells me that earlier when I was getting 25 megabits down, I was connected to the satellite. This test also seems to indicate that a single router likely wouldn't give me whole house coverage, unless a single Orbi router isn't a good test case.
And now as I've been writing this reply, I powered the satellite back on, and went to the spot where I got such bad signal earlier. I ran another speed test and now I got 90 megabits down, which was my goal this whole time. I haven't changed anything besides power-cycling the units. So now I'm totally confused.
