arrrroooooo
Mar 27, 2020Aspirant
Troubleshooting RBS50Y in Wifi Extender mode with R7000
With my outdoor RBS50Y in wifi extender mode synced to my home network R7000 and reusing the same network names (SSD), I'm having disruptions to the networking inside the house. I'm not sure where to...
CrimpOn
Mar 27, 2020Guru - Experienced User
There is "compatible" and then there is "entirely compatible". When used as part of an Orbi system, the RBS50Y acts like all the other Orbi satellites. Devices can roam between them. This is "entirely compatible". The RBS50Y can also be connected to almost any brand of WiFi system as an outdoor access point. This is "compatible" in the sense that any other WiFi extender is, with the advantage of being outdoor rated. A $50 WiFi access point from any vendor will connect to a R7000 and be "compatible", but devices will not roam betweeen the R7000 and the access point.
Sound like you made an expensive purchase and are not experiencing the reason "mesh" systems (like Orbi) are so popular.
Sorry.
