AllOuttaBbleGum
Jan 14, 2021Guide
True Factory Reset Sequence - The Real Way to Reset your Orbi
Posting this to help other frustrated Orbi owners. Finding a solution to this was very hard. I suspect a lot of "dead" hardware just needs to be reset properly. I bought a used Orbi RBR50 and R...
Jan 14, 2021Guru - Experienced User
A reset shouldn't be needed if it's new and out of the box from the Mfr. Only a 15 second press is needed for any factory button press. Possible the unit was used prior and was 3rd party resealed to make it look new in box as well. Seen alot of re-sellers repackage items.
Good Luck.
AllOuttaBbleGum
Jan 14, 2021Guide
Yes, it was used, as I mentioned.
