LM_HK
Nov 17, 2018Aspirant
Trusted devices are blocked
The following is my configuration:
SSID broadcast turn off
Access Control turned on and have all new devices blocked from connecting
All my own devices are added on the "allowed" list.
Nov 18, 2018Guru - Experienced User
What FW is currently loaded? What FW updated recently?
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Might try a factory reset on the Orbi router and setup from scratch and re-configure access controls. I would set up IP address reservations as well for devices that you are trying to control.
