lrotolo0420
Apr 24, 2024Aspirant
Trying to add a GUEST connection to ORBI
I need to add a GUEST wifi connection to my Orbi system. How do I do this and keep my existing log-in for family in the home?
May 02, 2024Guru - Experienced User
lrotolo0420
May 02, 2024Aspirant
I tried this and it didn't work.
- FURRYe38May 02, 2024Guru - Experienced User
What is not working?
- lrotolo0420May 03, 2024Aspirant
I cannot go to the GUEST login and find or add the network.
when I try to reset it, it says it is failed.
- CrimpOnMay 03, 2024Guru - Experienced User
To confirm: this web page was opened on the Orbi web interface (http://orbilogin.net )
(The Guest network "name" is on the right side of the web page.)
After clicking Apply at the top of the page and waiting for the router to reboot (2-3 minutes)
Then a device supporting WiFi does not detect any WiFi with the name given to the Guest network?
