lrotolo0420
Apr 24, 2024Aspirant
Trying to add a GUEST connection to ORBI
I need to add a GUEST wifi connection to my Orbi system. How do I do this and keep my existing log-in for family in the home?
lrotolo0420
May 02, 2024Aspirant
I tried this and it didn't work.
May 02, 2024Guru - Experienced User
What is not working?
- lrotolo0420May 03, 2024Aspirant
I cannot go to the GUEST login and find or add the network.
when I try to reset it, it says it is failed.
- CrimpOnMay 03, 2024Guru - Experienced User
To confirm: this web page was opened on the Orbi web interface (http://orbilogin.net )
(The Guest network "name" is on the right side of the web page.)
After clicking Apply at the top of the page and waiting for the router to reboot (2-3 minutes)
Then a device supporting WiFi does not detect any WiFi with the name given to the Guest network?
- FURRYe38May 03, 2024Guru - Experienced User
What web browser are you using to access the RBRs web page? Try MS Edge, Firefox or Opera.
Be sure to clear out all web browser caches as well.
