sandman512
Jan 09, 2021Apprentice
Trying to add a satellite to my RBR 50 mesh system.
So, currently have a RBR mesh system with TWO RBS satellites. I am attempting to add an additional RBS 50 and for some reason having massive trouble. I ran a CAT cable from one of the existing sate...
- Jan 11, 2021
Good to hear. You'll want to review your CAT5 cabling. CAT5 doen't support full 1000Mpbs connections well. CAT6 is recommended.
Please mark your thread as solved.
Enjoy. :smileywink:
sandman512 wrote:Update, so I was able to successfully configure it. First, I hard reset the "new" satellite. Next, I added it to my existing network(wireless). I then plugged a CAT5 cable from one of my existing satellites to the "new" one. All good now! Thank you!
Jan 10, 2021Guru - Experienced User
Is Daisy Chain enabled on the RBR?
Any LAN switches in the configuration?
sandman512 wrote:So, currently have a RBR mesh system with TWO RBS satellites. I am attempting to add an additional RBS 50 and for some reason having massive trouble. I ran a CAT cable from one of the existing satellites to the "new" satellite I am trying to add. For some reason it wasn't working. Any advice/input is appreciated. Thank you!
sandman512
Jan 10, 2021Apprentice
- FURRYe38Jan 11, 2021Guru - Experienced User
Enjoy. :smileywink:
