rsims42's avatar
rsims42
Trying to add a second satellite to Orbi RBR50
Hello experts,  I bought an Orbi RBR50 router plus 1 satellite which is working fine. I then bought an additional RBS50 satellite from Amazon to add to the system. It worked fine for a year but has ...
  • FURRYe38's avatar
    Nov 24, 2020
    Be sure the FW version is the same on the RBS as the RBR.
    Select Remove from the RBRs connected clients page.
    Factory reset the RBS then press the sync button on the RBS then RBR while you have the RBS near or in the same room as the RBR.
