Okiebob
May 23, 2021Aspirant
Trying to change WIFI channel
Netgear says that my security questions are invalid but they are correct so I can no longer access my router from my PC. I will be forced to do a factory reset. In order to get support from them, I m...
May 23, 2021Guru - Experienced User
It wasn't the last time I checked (its been a while) and I'm not at home to check right now.
A factory reset isn't hard to do.
Its a simple as pushing and holding reset for 7-15 seconds while the device is powered on.
And then reinstalling it.
No need to pay for a support contract .
