Canucksfan250
Nov 28, 2019Aspirant
Trying to connect chromecast to RBK50
So I have a RBK50 and I’m trying to connect to my chromecast. On my network it just gives me the error cannot connect to my network. I tried creating a guest network, and I managed to actually connect...
Nov 28, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Canucksfan250 wrote:
So I have a RBK50 and I’m trying to connect to my chromecast. On my network it just gives me the error cannot connect to my network. I tried creating a guest network, and I managed to actually connect. But immediately after it connected. It gives me the error Google home could not communicate with the wifi between your iPhone and chromecast so the chromecast may not be connected to wifi.
I connected to my ISPs router, which is a actiontec and it has no problem connecting to the 5ghz network. There must be a setting that is causing this issue with my Orbi. Any ideas?
Canucksfan250
It’s an actiontec t3000m or something, my isp did something on their end and reset their routers option which turned off the bridged mode and then I was double NAT, do you think that could be the issue? Do you know if there’s a way to access my routers admin page if I don’t have an Ethernet connection? New laptops don’t seem to have Ethernet ports:(
- FURRYe38Nov 28, 2019Guru - Experienced User
Yes, if they disabled brige mode on the modem, this would be one cause of your problems. Needs to be in bridge mode if at all possible. The RBR is already a router which doesn't need another one in front of it.
- michaelkenwardNov 29, 2019Guru - Experienced User
A lot of people find that rather than "bridging" the first router it easier to put an Orbi router into wireless access point (AP) mode.
