Canucksfan250
Nov 28, 2019Aspirant
Trying to connect chromecast to RBK50
So I have a RBK50 and I’m trying to connect to my chromecast. On my network it just gives me the error cannot connect to my network. I tried creating a guest network, and I managed to actually connect...
Canucksfan250
It’s an actiontec t3000m or something, my isp did something on their end and reset their routers option which turned off the bridged mode and then I was double NAT, do you think that could be the issue? Do you know if there’s a way to access my routers admin page if I don’t have an Ethernet connection? New laptops don’t seem to have Ethernet ports:(
Nov 28, 2019Guru - Experienced User
Yes, if they disabled brige mode on the modem, this would be one cause of your problems. Needs to be in bridge mode if at all possible. The RBR is already a router which doesn't need another one in front of it.
- michaelkenwardNov 29, 2019Guru - Experienced User
A lot of people find that rather than "bridging" the first router it easier to put an Orbi router into wireless access point (AP) mode.
