rbaron
May 25, 2018Tutor
Trying to connect my ORBI to my modem to see my home cameras
My goal here is to see my home cameras. That being said, here is the issue.
I used to have an Apple Airport Extreme Router but I changed it to the ORBI AC 3000 Router with two satellites. I als...
May 25, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem? Built in router here?
What mfr and model are these cameras?
- rbaronMay 26, 2018Tutor
The modem is a Centurylink modem Model# C2000T. As far as the cameras, I am not sure.
I know it is just a setting somewhere. I have the ports open on the modem. Port 80 and 37777. The IP address is set to 192.168.0.20.
On my ORBI router, I know how to open the port 80 and 37777 but the IP address I am not sure of. Should I set it to the same as the modem? Using 192.168.0.20? Because the ORBI I THINK uses the 192.168.1.xxx scheme. Would changing it to the xxx.xxx.0,20 scheme work?
Thanks for the help
