rbaron
May 25, 2018Tutor
Trying to connect my ORBI to my modem to see my home cameras
My goal here is to see my home cameras. That being said, here is the issue.
I used to have an Apple Airport Extreme Router but I changed it to the ORBI AC 3000 Router with two satellites. I als...
May 26, 2018Guru - Experienced User
Your ISP modem is a gateway router already. So you have two routers online thus a double NAT condition. You need to try one of the following:
1. Bridge the ISP modem.
2. If the modem can't be bridged, use it's DMZ for the IP address that the Orbi router gets from the ISP modem.
3. Use the modem as your main router and configure the Orbi router for AP mode.
rbaron
May 30, 2018Tutor
I'll need to do some research on how to do the things you suggested.
Thanks mu
- FURRYe38May 30, 2018Guru - Experienced User
Let us know how it turns out...
- rbaronMay 30, 2018Tutor
Ok, after some fiddling with all the settings I was able to get it to work.
The DVR was set to xxx.xxx.1.20 So I needed to forward the port on my ORBI to xxx.xxx.1.20.
On my Centurylink modem, I had to port forward xxx.xxx.0.58 because that was what the modem gave the router as an IP address.
So the ORBI is a .1.xxx device and the modem is a .0.xxx device.
Anyway I got it to work and I am happy.
Thanks much...... Rich
