rbaron
May 25, 2018Tutor
Trying to connect my ORBI to my modem to see my home cameras
My goal here is to see my home cameras. That being said, here is the issue.
I used to have an Apple Airport Extreme Router but I changed it to the ORBI AC 3000 Router with two satellites. I als...
May 30, 2018Guru - Experienced User
So is your modem still in router mode or did you set up the modems DMZ for the IP address of the Orbi router? If you are using the modem in router mode and using the Orbi in router mode, you'll need to use the modems DMZ for the Orbi router. This will help with these issues.
rbaron
May 31, 2018Tutor
No, I did not set up the modems DMZ for the IP address of the Orbi router. It was like this:
DVR is set to 192.168.1.20. This is the IP address given to the DVR by the Orbi.
Orbi port forwarding was set to 192.168.1.20, with two ports open.
Modem port forwarding was set to 192.168.0.58, the IP address of the Orbi.
I hope that makes sense because it works and I am happy.
