rbaron
May 25, 2018Tutor
Trying to connect my ORBI to my modem to see my home cameras
My goal here is to see my home cameras. That being said, here is the issue.
I used to have an Apple Airport Extreme Router but I changed it to the ORBI AC 3000 Router with two satellites. I als...
May 31, 2018Guru - Experienced User
I would later on set up the DMZ on the modem if your going to use the Orbi router in router mode. Will help since you have two routers on the same network line.
Enjoy.
