AllOuttaBbleGum
Oct 14, 2019Guide
Trying to connect RBS20 Satellite to RBR50 - Shows Connection Type Offline
I have a functioning RBK50 with an RBR50 and RBS50. I bought a used RBS20 which powers up and I was able to factory reset it. When I look at my Orbi app, it shows as attached (connected) to the RBR...
CrimpOn
Oct 14, 2019Guru - Experienced User
What method did you use to sync the new satellite to the router?
- AllOuttaBbleGumOct 15, 2019Guide
I followed the Orbi app process on my iPhone. Power on, wait, hit the Sync button, wait. I consider myself capable with networks. I can setup routers on a DMZ, create static IPs, and open/close ports, firmware, make my own RJ45 cables yada yada yada but I wasn't sure how to proceed next with Orbi. Plus I've turned many of these "functions" over to my youngest son LOL.
- CrimpOnOct 15, 2019Guru - Experienced User
Hmmm. I use the web interface "Add a Satellite".
Anyway.... You pressed the sync button on the satellite and on the router, correct?
The first time I only pressed it on the satellite since the app only says to press that one and the router did not find the satellite. The second time I started "what the hell" mode and started trying things so I pressed it on both the router and the satellite. That time it found the satellite but there is no connection to it. It shows up in the map.
