AllOuttaBbleGum
Oct 14, 2019Guide
Trying to connect RBS20 Satellite to RBR50 - Shows Connection Type Offline
I have a functioning RBK50 with an RBR50 and RBS50. I bought a used RBS20 which powers up and I was able to factory reset it. When I look at my Orbi app, it shows as attached (connected) to the RBR...
Oct 15, 2019Guru - Experienced User
I would try hardwiring the rbs20 into your main orbi router and get your firmware updated on it. Its a bit behind. so I'd try updating the firmware, factory resetting the rbs20, and then try to pair it with the system.
AllOuttaBbleGum
Oct 15, 2019Guide
I will try to update the firmware....
