bob999's avatar
bob999
Trying to connect RBS40 to RBR20
I have a working RBR20 and RBS20 system. I have acquired an RBS40 as an additional satellite. I cannot get the RBS40 to connect to the network. The Orbi app sees the RBS40 but the connection type is ...
  • FURRYe38's avatar
    What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
    Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
